Just visited a local garage, they tried their "Launch" system on it, car wasn't listed. Then tried a Snap-on system, car was listed (engine code 176.B9) but it didn't work either.
Apart from getting an arm ripped of by a Fiat dealer, anyone got any recommendations?
Right, after much time, effort and help, I finally have some code working that can read basic values from the ecu.
The only requirement is the purchase of a ~£10 VAG COM 409.1 lead, which you then have to either modify yourself or spend another couple of quid on a 16 to 3pin (with power) adapter.
My engine is not running quite right at the moment so if anyone with a MK1 1.2 16v engine with the 18FD ECU is interested in reading codes etc. from their ECU, please can you try the app in this thread:
I'm in simliar boat lol I have a 16f ecu on my mark1 1.1 97 punto.
My IAW/Injection light stays on, And I've tried 3 garage's so far with no luck in getting the ecu read
Was just wondering if your plan worked, As I might try doing it at home myself, providing I get the rite stuff.
If it's the 16F, barnacle's app (see the 16F thread above) works fine with a modified VAG-COM cable - or you buy the VAG-COM and 3-Pin adapter and not have to mess about with a soldering iron
And yeah, the 16F app works on the 18FD but I could never get barnacles app to work so I modified brainsucker's 16F app to work with the VAG-COM cable.
Also what sort of PSU would I need, as that cable convertor has got red/black crocodile clips lol
Just thinking this might be the better option, As I'm ok on the computer, And even if I find a garage that will read the ecu and clear it, I'll only have to pay again if it comes back on.
My ecu details are attached.
Dave
931.6 KB
Thanks for replying matey, this afternoon had another bash at car, and fount out it was my rev counter wire, shorting the ecu. it was trapped/crushed behine the heater assembley
Thanks will save info as i might invest in one soon so Ive got one.
I heard that it also work with ELM327 + 3 pin adapter and this software http://www.fiatecuscan.net/
Anybody tried qith Punto 1.2 16V MPI? (or any MPI) - ECU IAW 18FD.5Z
