Hi everyone.
On our way to Skegness the other day we had a loss of boost after crossing the river Trent. Then we noticed an extra warning light over and above the usual check running lamps.
We also noticed the stop start button has a yellow lamp which is also different.
So I didn't want to stop because temp ok, no smoke or nasty noise, we are still moving & it may not restart... Holiday over.
As Emma wanted to stop & check we did. No oil in water no water in oil or burning smell.
Car restarted with a beep check engine & stop start not available. Car drove with boost.
It's probably got a sensor reading out of expected perimeter?
So I'm going to see how the drive is on the way home and use the rac if required.
In the meantime which lead will I need to hook the car to a laptop please?
Thanks all.
Thanks all.
