derbyshire gp
Member
HELP.....
Can someone point me in right direction....
2012 punto
when car is running during the day ie no lights on (only day time running lights)
everything is fine
However come night time switch on lights and within a few seconds or minutes get error triangle and check running lights
Now heres the bit i dont understand
i checked all lamps/bulbs all okay.
apart from rear passenger led which was dim(see other threads)
so replaced entire cluster bingo no more dim leds on passenger side:worship:.......
but then i get error triangle flash up check running lights :bang:
What is going on ......
do i need to get ecu cleared of codes? is there a way of forcing a manual reset?
the only day running lights on the car are in the front head lamps and they seem fine....if they were faulty or on their way out surely it would come up on dash with out head lamps on ?
please help
2012 punto
everything is fine
please help
