Old 27-06-2020   #1
Ireland
8v to 16v with a head start
Well lads so I知 looking to swap the 8v in my 2002 mk2 with a 16v. Now I know this topic has come up many times in this forum but this is different. I know you need the loom ecu bcu (which I think is the fuse box under the bonnet?) and the ignition barrel for the swap. Now I知 lucky to own another mint mk2 sporting with a ****ed engine and a virginised ecu for a 16v engine which I think will learn the bcu if I知 correct. Being a sporting it has the 6 speed box, So I have a bit of a head start with the swap. So I wondering will the virginised ecu be of use? Can I just get a 16v engine and noting else? And I know that I could buy another sporting for the price of the swap, I am well aware that it値l be more expensive to do this but I知 desperately in love with this car and I壇 Rather spend double the money on her if needs be. Thanks boys. Ronan
Likes RallyJapan liked this post
Specs43 is offline Reply With Quote Quote
Old 28-06-2020   #2
Ireland
Re: 8v to 16v with a head start
Any help would be great boys
Old 29-06-2020   #3
judderbar has donated!
Finland
Quote Originally Posted by Specs43 View Post
i think you will find the security system of Fiat is sufficiently robust that you need to do a like for like replacement of a virgin ECU. You need the 16V electronics as already described.
judderbar is offline Reply With Quote Quote
Old 29-06-2020   #4
Ireland
Ok so, ecu should do the job? and I致e all the electrics from the sporting so should be all good there
Old 30-06-2020   #5
Finland
Ok so, ecu should do the job? and I’ve all the electrics from the sporting so should be all good there
You cannot put the 16V ecu and 16V engine into the 8V car, where you have only replaced the 16V engine and ECU
Thanks Specs43 thanked for this post
Likes Specs43 liked this post
Old 04-07-2020   #6
Ireland
So your saying I would have to replace all the wiring from the 16v to the 8?
Old 04-07-2020   #7
Finland
In your first post you say you know you need the wiring loom ECU and BCU. The BCU is not the engine fuse box. It the fusebox and computer inside the car.
Old 05-07-2020   #8
Ireland
Ok great thanks for the advice
(T) 1.2 16V head on 1.4 16v Starjet with variator antonHr Grande Punto 2 17-04-2020 22:03
(Tu) 1.4 16v head on 1.2 16v block? 1PuntoCarl2 Punto (Mk2/2b) 4 12-02-2013 22:14
(G) Changing mk2b 8v head for 16v head???? Anfield Punto (Mk2/2b) 5 19-05-2008 00:06
(G) punto 16v head gasket head problems philmoore Punto (Mk2/2b) 6 11-03-2008 18:36
(T) 1242 8V Head to 16V Head TurboCinqy1250 Cinquecento / Seicento 8 05-11-2006 07:14
