adamwills1982
- Nov 2, 2016
- 18
- 4
Ah right, yes I just checked, dynamic. I've had several renaults, so automatically put Dynamique.
Just outside Cardiff
To play devil's advocate the Multi ECU scan software (MES) is free and the adaptors are under £20. You do however need a Windows computer to connect to. The paid-for versions of MES have additional functions.
My money is on the battery so connect a voltmeter and watch what it shows. Stick on types are about £5 on eBay. Wire it to any ignition On positive wire so its off when ignition is off.
Correct. You need to carry the jump leads and try them if the fault appears.
Robert G8RPI.
WIll removing the motor altogether make the steering lighter than when driving it with the fault? If so this will be my choice next time my fails consistently. At this stage after I did the contact cleaning (2 years ago) the steering has only failed a couple of times and this when trying to full lock or fast parking manoeuvring at stationary speeds.
The whole steering set up is designed with the motor in place and working, without it the steering could behave unpredictably.
Cheers, this answer suggest is not possible to drive without the motor then. So a solid steering shaft will be required to replace the one assembled with the motor. Such shaft does not seem to be available for the MK2, so no easy options available really. From memory driving with the steering light on (not functioning motor) is very heavy but seems safe. I suppose this will be a MOT failure? so not acceptable for long term use.
This is why I wanted to know if removing the dead motor steering may get lighter, but then this is not possible as mentioned earlier.Reason Steering goes so heavy when the Motor isn't working is that as well as turning the steering without assistance you are also turning the dead motor.
