T TONY55S Patron member Joined Oct 10, 2010 Messages 393 Points 260 Oct 21, 2017 #1 hi,does anybody know what fuse is needed for the heater fan? tks tony
I Italian Job Member Joined Jan 16, 2006 Messages 325 Points 84 Location Rome Oct 21, 2017 #2 Engine fuse box F8 30 amp See attached Attachments Fuses.pdf 171.8 KB · Views: 67
D DaveMcT Distinguished member Written a guide Joined Sep 14, 2009 Messages 19,492 Points 3,295 Apr 5, 2020 #3 If the fan works on full speed your fuse is fine. If the fuse has blown, put the fan on full speed before turning the ignition on. If the fan runs only on full speed you will need to replace the speed control resistor. Good luck with that. See my thread on the subject in the Panda II forum. Last edited: Apr 5, 2020
