Following on from my recent posts about thermostat problems on my son's Mk1 Punto, he now has quite separate troubles with the damn thing.
He bought this car two months ago (regretfully!) and, in addition to various other things, cold starting has never been easy. Generally, though, it has usually started after several attempts. The other day it wouldn't have it at all, so he called out the RAC. Their chap said that there was a 'healthy' spark, and that it must be a fuel problem, so he sprayed something into what passes for a carburettor these days and away it went.
Since then it just doesn't seem to want to know. His first thought was that the coolant sensor could be responsible, so he decided to investigate around this area. Measuring the resistance of the sensor when cold produced a reading of around 7k Ohms - which we thought about right - and there was +5Volts on its input, so (we think?) that everything around there is in order.
When the ignition is turned on, fuel pump operation can be heard - so, again, that seems to be ok.
Does anyone have any further ideas about what might be causing this problem?
:bang:
:bang:
