Old 04-10-2007   #1
Gear Selector Problem?
While changing gears from 1 to 2, if I am not careful the gear stick can get lost near the 2nd gear... Little hard to explain so I have made a quick pic. The black is obviously the normal route the gear change should be, then the red is where the stick seems to get lost.
http://www.imagehosting.com/show.php...gears.JPG.html
If i dont move it back into second carefully the whole gear change messes up. It allows me to move the gear stick freely, in circles or what ever. It then can only access gears 3, 4 and reverse. Then I have to take the gear selector out and put it back in place, which can be a pain because im no mechanic.
But what is causing the problem? Any ideas?
ste713 is offline Reply With Quote Quote
Old 10-10-2007   #2
Re: Gear Selector Problem?
I had the same problem when i bought my punto, but in my case it wouldnt spring back into nutral, what sorted my problem out was, the gear selecter was stiff, so i disconnected the gear stick, took out the gear selector, got this sand paper material from halfords for cars, which i used to scrape of the dired oil, then used so grease and its has been fine from now on 10 months down the line. hope you get it sorted mate.
Giu85 is offline Reply With Quote Quote
Old 13-10-2007   #3
It all looks clean in the gear selector... No dry oil or anything...
I kinda got use to driving it with the problem, but when it happens it happens at the worst times. All linkage looks fine, so I really dont know.
Back out to do it again now
Old 13-10-2007   #4
-~Moderator~-
a1ant's Avatar
Trader Rating: 1
a1ant has donated!
Have had the same problem. You need to remove your battery and battery tray and use some fine sandpaper on the gear selector....
See this https://www.fiatforum.com/punto-tech...ing-stiff.html
Sorted the problem out for me. As it says, dont use any oil/greese etc on it, as it will only make it worse!
Cheers, Alan
If you see a problem post, please click the report button
a1ant is offline Reply With Quote Quote
Old 13-10-2007   #5
Will give this a go... Although stiffness is not my problem, its the gear selector slipping out of place.
(T) Fiat Punto gear selector problem evildanger Punto (Mk2/2b) 10 22-05-2007 22:53
(T) Punto Mk2 HGT Gear Stick Help D4R73N Punto (Mk2/2b) 3 03-02-2007 02:17
(G) Shifting to first gear on my Bravo? cghorayeb Bravo / Brava 7 09-12-2006 22:16
(T) Another Clutch / gear box issue Zimon Cinquecento / Seicento 15 03-07-2005 14:55
(S) Gear Knob Replacement polecat Marea 0 15-02-2004 23:09
