While changing gears from 1 to 2, if I am not careful the gear stick can get lost near the 2nd gear... Little hard to explain so I have made a quick pic. The black is obviously the normal route the gear change should be, then the red is where the stick seems to get lost.
http://www.imagehosting.com/show.php/1216047_gears.JPG.html
If i dont move it back into second carefully the whole gear change messes up. It allows me to move the gear stick freely, in circles or what ever. It then can only access gears 3, 4 and reverse. Then I have to take the gear selector out and put it back in place, which can be a pain because im no mechanic.
But what is causing the problem? Any ideas? :bang:
