Here's something I don't understand. 3 days ago our Panda - 2010 1.2 60hp engine Dynamic Eco - Failed to fire up on the first turn of the key. She always fires first turn after going over compression about half a dozen times. She cranked for at least twice as long before I released the key and tried again when she them fired up after just slightly longer than usual. Also she "stuttered" a wee bit before settling down to even running, probably due to a bit of excess fuel lying about? Mrs J drove the car later in the day and reported no problems but I doubt if she would know the difference as long as the engine managed to fire up eventually. Then she did it again the next morning when I went out to start her.
We both follow the same start procedure - Turn the key to the "run" position and wait for the padlock light to extinguish then turn it onwards to activate the starter motor. As the key is turned to the first position I always listen for the fuel pump running, which it did.
Yesterday though she fired up just as she always used to. I'm not sure why really but my mind is thinking it's more likely to have been an ignition problem because of the need she showed to "clear her throat" when she did fire up. I suppose it'll take a "no start" before I can really track it down as there are no DTCs posted at this time. Most likely a poor connection with the crank sensor being most suspect? Just wondering if this is a "known issue" and if so what's most likely to be the problem? Thanks to anyone who might like to speculate.
