SmallBluePanda
- Jul 26, 2021
- 2
- 1
Hi everyone,
Apologies for the length of this (my first) post, but I need some advice from the more experience mechanics among you.
I've just done a quick head gasket and sump gasket swap on my son's '06 Panda that was leaking oil from the top and bottom of the engine. As far as I can gather, it's an EV02 1.1 litre engine. Everything went pretty smoothly and I didn't have any big bits left over at the end of the job.
I filled the engine with oil and the coolant system with water (just in case I had to drain it again) and the engine started first time. It ran smoothly at fast idle for a while and then the revs dropped to normal idle. I tried bleeding the coolant system, using the heater hose bleed screw, and a weak coolant mixture (but no air) came out of the bleed fitting. The heater had started to warm up at this point, so things seemed to be working as planned.
I stopped the engine, refitted the bleed screw and removed the coolant filler cap to see whether I needed to top it up. I was surprised to see the water level had risen well past the top marker on the header tank. I re-started the engine without replacing the filler cap, to check whether I'd not tightened the (new) cylinder head bolts properly.
Sure enough, the fluid level rose and started overflowing the filler as the engine sat idling. Strangely, when I blipped the throttle the level dropped, which is the opposite of what I'd expect to see if the head gasket was leaking. I repeated the test three or four times and every time the revs increased the water level dropped, starting to rise again as the engine idled.
Has anyone else experienced this behaviour? I don't want to push ahead with trying to clear a coolant airlock if that runs the risk of damaging the engine. On the other hand, I don't want to replace a perfectly good head gasket and bolt set if it's just a tricky airlock.
Any help or opinions would be gratefully received
