Old 3 Weeks Ago   #1
Fiat panda 2005 1.3 multijet
Hi
I have just had my clutch replaced and now have a problem if anyone can advise please.
When starting the car from cold I have the oil light on for about 6 seconds and the engine sounds fine but after the 6 seconds the oil light goes off and there is a swishing noise this noise goes away when the engine is warm.
This definitely didnít happen before clutch was replaced.
l33rsk is offline Reply With Quote Quote
Old 3 Weeks Ago   #2
Re: Fiat panda 2005 1.3 multijet
swashing noise sound like bubbles in a pipe behind the dash ?
I take it you have checked the oil level and for leaks ?
Thanks l33rsk thanked for this post
koalar is offline Reply With Quote Quote
Old 3 Weeks Ago   #3
Thanks for reply
The noise is hard to explain wizzing noise itís not a knocking noise or a bearing rumble. Yes the oil level is fine. When the noise seams to stop I have used a screwdriver as a listening tool and it seams to be coming from sump. Iím thinking possibly oil pump but how has this happened with the car having a clutch replacement.
Old 3 Weeks Ago   #4
Quote Originally Posted by l33rsk View Post
Thanks for reply
I guess the First thing to do is to log the faults with the garage that changed the clutch.
if they have caused the faults, they should repair them free of charge
Old 3 Weeks Ago   #5
Had a few issues with the garage and tried to sort them out but letís just say I saw a different side of him so wonít be going back there.
Old 3 Weeks Ago   #6
the First thing to check is the oil pressure switch
Do you have a multi meter ?
obviously if the oil pressure isn't there you will be damaging the engine
the switch only has one terminal
Check its plugged in properly ?
disconnect the connector and measure the resistance from the switches terminal to battery negative. While observing the resistance start the car.
report back the values and how quickly it changes
Old 3 Weeks Ago   #7
Ok thanks I have a multimeter with ohm setting which setting shall I use I have 2k 20k 200k or 2m?
Could this be caused by clutch replacement or simply just a coincidence?
Thanks koalar thanked for this post
Old 3 Weeks Ago   #8
2K range
not a big believer in coincidences. They do happen.
I can't see a connection between the clutch and oil pressure. Shouldn't even need to touch the turbo or its plumbing for a clutch change.
need to concentrate on the oil pressure First.
the light is computer controlled. First we need to check if it really has low pressure at start up. Hence testing the switch directly first.
Old 3 Weeks Ago   #9
was an oil change done at the same time ?
Old 3 Weeks Ago   #10
Netherlands
Did they forget the groundstrap to engine?
gr J
"Look for the ridiculous in everything and you will find it". - Jules Renard
A3jeroen is offline Reply With Quote Quote
Old 3 Weeks Ago   #11
Thanks I will test the switch, no the oil hasnít been changed as for the earth strap Iím sure itís on but will double check.
Old 3 Weeks Ago   #12
Quote Originally Posted by A3jeroen View Post
gr J
Sure itís on but will double check. Thanks
Old 3 Weeks Ago   #13
Semper Ubi Sub Ubi
Goudrons's Avatar
Goudrons has donated!
Have you checked the heat exchanger under the oil filter housing/oil filler pipe?
They are prone to leaking and it might be causing a bit or aeration which is why the oil pressure sensor is lit up at cold start.
Likes koalar liked this post
Goudrons is offline Reply With Quote Quote
Old 3 Weeks Ago   #14
Quote Originally Posted by Goudrons View Post
I havenít I will check that thanks
Old 3 Weeks Ago   #15
Quote Originally Posted by koalar View Post
2K range
Key off 0.00-0.01
Key on mar before starting 0.36 dropping down by 0.01 each reading until it got down to 0.26 then I started the engine
When started 1.90, 0.88, 0.24, 0.17, 0.14, 0.08, -0.03, -0.01, -0.04, -0.09, -0.13, -0.17, -0.13, -0.17, -0.22, -0.25, -0.30, -0.31, -0.30. -0.31, .0.29, -0.28, -0.26, -0.25, -0.24, -0.23, -0.22, -0.21, -0.20, -0.19, -0.18 then 1.
When it stayed on 1. Thatís when the winning noise starts.
Hope this helps I could have slipped off the positive connection on the switch while doing this. Thanks
2005 1.3 multijet panda. grofaz18 Newbie Central 1 20-10-2008 00:11
