Wasgehabendas
- May 18, 2018
- 119
- 35
Hi guys,
I hope you aren't panicked from this stupid conspiracy that wants to take our liberties away and remove all our human rights as George Orwell predicted in his 1984.
Some 10k miles back I got hiccups / misfire when car is idled for more than 1 minute. Now, in the last 3-4k miles I am getting hiccups 3-4 seconds after being idled. When engine is cold, they are not that bad, but when it gets warm then hiccups are worsening.
Spark plugs are new and OEM. Tried with 2 different types of HT leads and nothing has changed. I am not planning to waste more money until I find the issue. Local mechanics say it is nothing to worry about but it bothers me and I wouldn't like to drive a car that has clearly some fault.
Just not to forget, car has a new fuel pump and scan tool showed nothing, electrician was 100% sure that everything is correct with the car. Sometimes car has longer cranking, and very rarely dies immediately after being started. Not sure if these things are related to the hiccups.
Muffler is not in perfect condition as it showed some signs of wear and has a small leak.
What are your thoughts beside plugs and wires? Maybe injectors, coils, wiring loom, ecu?
Best regards
Best regards
