im Axle Specialists
Thread Tools
Old 12-01-2020   #1
Electrical diagram Panda 2004
I need the electrical diagram for the Panda 1.2 fuel injection model showing the supply to the electric fuel pump . There are 4 connections on the top to the pump.
There is no 12V coming to the connector at the pump. I think that there is no signal activating the fuel pump relay situated under the bonnet. I have read elsewhere something about a fire cutoff under the seat. Is that on all models ?
Any suggestions ? Thanks
Mypanda is offline Reply With Quote Quote
Old 12-01-2020   #2
Netherlands
Re: Electrical diagram Panda 2004
Yep. Fuelcutoff is on every Panda.
gr J
Likes Mypanda, varesecrazy liked this post
"Look for the ridiculous in everything and you will find it". - Jules Renard
A3jeroen is offline Reply With Quote Quote
Old 12-01-2020   #3
varesecrazy has donated!
Little black panel..
Never had to use mine in 15 years.. but others have had issues
Likes Mypanda liked this post
Old 12-01-2020   #4
Unfortunately it didnt help pushing the button. Do you know if the button just is a simple contact? If so, I will try and get to the button and short it to see if the cut off itself is faulty.
I would still love to see the electrical circuit for the fuel pump and to understand the 2 small terminals on the pump. The 2 big ones are for the +/- 12Volts for sure.
Old 12-01-2020   #5
Worth disconnecting battery for an hour..
There are several things that drive the pump..
Its supposed to run up the rail pressure.. then cut out.
Worth putting a meter on the power supply for pump.. as you
1. Reconnect
2. Prime pump during MAR : selftest
There is always a chance the pump has an issue and cooked a fuse..or relay
Whats the history of the car?
One might reset.
Old 15-01-2020   #6
Spain
The two small terminals are from the fuel gauge
Txuchin is offline Reply With Quote Quote
Old 15-01-2020   #7
Spain
Editado
Old 15-01-2020   #8
Spain
Quote Originally Posted by Txuchin View Post
https://www.dropbox.com/s/oj7fv36v4s...bomba.png?dl=0
Old 17-01-2020   #9
Quote Originally Posted by varesecrazy View Post
1. Reconnect
One might reset.
I have applied 12 volts directly to the pump with no reaction.I think it must be the pump that just isnt working. I will wait to remove the pump until I have a spare available. What did you mean by MAR selftest?
Old 18-01-2020   #10
Quote Originally Posted by Mypanda View Post
Do you know if the button just is a simple contact?.
No, its a ball bearing on a spring in a cage, with the shock of a collision the bearing is thrown around and deforms the cage breaking contact and so shutting down the fuel pump, pressing the button resets the cage and centralises the bearing, making contact so the fuel pump can receive power once again.
Large potholes emergency braking and even strong winds can cause enough force to operate the inertia switch (proper name) especially on older units where the spring has gone weak with age.
Likes Jockcl500, SPORTPACK50 liked this post
2009 Fiat Panda Eco Active
2012 Microcar MGO SE, 1998 Reliant Robin Estate
2012 Royal Enfield 500 EFI Bullet
2007 Honda Deauville NT700ABS
2x 1984 GL1200 one with Palma Sidecar
09 johno is offline Reply With Quote Quote
Thread Tools
(T) Electrical diagram engine punto 85 giuseppe Punto (Mk1) 1 01-03-2014 18:27
(T) Stilo electrical diagram RJose Stilo 4 12-04-2010 12:12
(T) Electrical Circuit Diagram mattman Cinquecento / Seicento 7 06-12-2006 17:29
(G) UNO electrical wiring diagram PAK_UNO Uno 10 24-09-2006 12:07
Panda 2004/5 - Wiring Diagram PandaUK Security 0 29-05-2005 10:57
