newbie fiat
- Aug 4, 2016
- 96
- 27
Looking to replace my timing belt, however there seems to be 2 different sizes for my engine on every site i go on, euro car parts, gsf car parts, car parts online to name a few, they are the same length and number of teeth but are either 15 or 22 mm wide (this is when searching by VRM by the way) even the gates belt finder shows as both sizes for my car, is there a way to confirm or am i going to have to remove the cover and measure manually?
i have a 2005 1.1 fire engine 187A1000 (square oil filler cap)
i know the auxillary belt is 15mm i only get the one option for that going to change that at the same time.
i was also thinking water pump but read they can be more hassle than they are worth, mine is currently not leaking and was changed 3 years ago with fresh coolant, i then changed the coolant myself 1 year ago as i did a full service, oil, oil filter, air filter, coolant, spark plugs so i cant see there being a problem any time soon (hopefully), looking to keep the car another 2 - 3 years hence the belt change.
