Just back from the MOT centre...
Emissions..PASS
Headlights..PASS
Brakes... FAIL..
Rear brakes / Handbrake is 10% which should be 16% on one side. The other isn't a great reading either. Though multiple times I've had issues with it holding on the hill etc so not too surprised this is catching up on me.
The front brakes passed, but one was just one digit away from being a fail or at least an advisory at 29 and should be below 30.
So I'm thinking full brake overhaul?
Fronts: pads replaced last august with cheap ones. They've been squeaking continuously for months now and last time we looked it looked fine, put it down to a clip being loose. Disks are chunky enough as are the pads, but this car has had issues of uneven pad wear so if I get new pads, what else should I get to stop this once and for all?
Rears: Only ever looked at the drums. Sure enough a typical mechanic had tampered with them as I learnt before I owned the car but now it must be addressed. What should I do here, new handbrake cable, new drum shoes, new drums?
I've 21 days but I'd like to order and fit these as soon as possible so I can drive my car so what's your advice and what parts should I go for? Don't mind forking out for Fiat if it means I get parts that aren't made of cheese.
Emissions..PASS
Headlights..PASS
Brakes... FAIL..
