Decided to have a look and see if i can sort my squeeky brakes and have a look at bottom engine mount as have a bit of a rock on over run.
brakes were fine but had a tug at the drop links and round the front suspension found the bottom wishbones/control arms are well worn plenty of play.
also bottom engine mount is worn so ordered one that will be a easy fix.
the control arms look easy to replace and found some on fleabay for £50 for the pair.
not in a rush to do them but do need doing.
has anyone any tips or done it and had problems, looks like the ball joint pinch bolt is the rusty bit would you suggest buying new ones before starting
any help appreciated
Jon
Jon
