The O rings are available, part number 14457680. £3.50 each last year.
The really difficult bit would appear to be getting your carpet dried out once you have capped the leak. I'm still having to perform occasional inside scraping of the windscreen in frosty weather as there is still a bit of moisture trapped in the under carpet foam type stuff. The leaked coolant has been very reluctant to evaporate away and I haven't been able to get rid of it all yet. Here's hoping for another cracking summer next year so that I can leave the doors open, when I remember to!
wish me luck..I'm going in..!!
varesecrazy Panda is a 2004 Active iirc.
it WAS a leaky Matrix, 9 years and 77K miles later..
weepy seams on the end / plastic to metal Flange / joint,
just one of those things..,
Charlie
Can you bring the old with you tomorrow to gander at out of interest please
as I'm now about to buy a licence for my various vehicles in my FIAT fleet
Fan motors are on Ebay. Once glovebox removed, access looks ok.
Now I have an engine management light on and a P0106 - MAP/Barometric Pressure Circuit Range/Performance Problem OBD error message to deal with. A bit more research is now required and a possible new thread coming up
My poor 9 year old Panda sems to be having a mid-life crisis!
Sorry Varesecrazy..................... I wasn't expecting a response to my rhetorical-ish P0106 OBD meanderings.
It's got one of those magnificent Multjet 1.3 diesels in it.
After a bit of digging, and please excuse my naivety, it looks like the P0106 OBD code points at the MAP (Manifold Absolute Pressure) sensor not being happy with what it is detecting, or it is faulty. I therefore cleaned the MAP sensor, which seemed to have a fair bit of black mayonnaise in it, but that didn't seem to help. Further research inidicates that MAF (Mass Air Flow) sensor might also have a finger in this pie. So I've just cleaned the MAF sensor as well, which actually looked pretty clean even though it has never been cleaned, and I am just letting it dry off before putting it back in. For info - both sensors generously sqooshed with Wynn's Electrical Contact Cleaner spray (which is just Isopropyl Alcohol).
For anyone looking at poking these sensors, the MAF sensor, which is on the end of the big pipe at the front right of the air box, is easy to get at. The MAP sensor, located underneath the air box and at the top rear of the engine, is a bit more awkward to get at. If you have a screw driver (for the pipe clamp) and small socket set handy (for the sensor to air box set screws) MAF sensor removal would take 5 minutes. You will need a screw driver (for the pipe clamp at MAF end) and an Allen key (3mm it think) to get the MAP sensor out and that job would take 10 minutes.
Whilst waiting for the MAF to completely dry off, could anyone please advise if the EM light will self-extinguish if I have managed to clear the issue, or will it stay on until it has been told to go away? If it will just stay on I might end up with the car in bits and a little glowing bulb!!!
