gar074
Prominent member
Has anyone else had problems with their remote key fob only working after 3-4 presses of the button?
Mine worked absolutely fine first time until a few weeks ago, when it started to play up. I installed a new battery, but it still worked erratically. So I bought yet another battery, in case Halfrauds had sold me a dud, and it still only worked erratically. (And before you ask, I did buy the correct battery - same serial number as the original). Sometimes it works first time, at other times (with no apparent rhyme or reason) it needs several presses before it operates.
I've tried to analyse its erratic performance scientifically (distance from the car, position of operation in relation to the car, phase of the moon, etc) but there's no apparent pattern to its misbehaviour.
Any suggestions? And if the key's knackered, do you reckon that a replacement would be covered under the warranty?
