- Apr 2, 2011
- 57
- 19
Car has now been rebooked for 19th Nov so a bit longer for the part to be fixed but im going on hols and didnt have the time on friday to get it repaired...
As for the posts re sticking back doors i have sprayed a thin film of silicone spray around the rubbers and the problem has been solved. Mine was only slight if the door hadnt been opened for 4-5 days. The silicone is water resistant and will stay on there for months at a time. Had a similar problem on my punto so i know in the long term it works a treat!
Unless its a re-engineered replacement wouldnt it just happen again?
Just out of interest, if the problem happens again, and the warranty period ends - and it continues to malfunction, would the replaced part still be under guarantee or would us unlucky owners have to then pay for subsequent replacements? It is a dark picture I've just painted, but I'm just curious
My boot lid was repaired last week, and the replacement driver's door beading was also fitted - but not perfectly: they admitted they'd had trouble making the new one lay flat even with warm air. It's a big improvement, but still not as good as the passenger door. I've been told to take it back if it gets any worse.Also - Sod's law, the number plate light fault refused to materialise on test. I expect slamming the boot lid a few times will regenerate the fault! And I do mean slam, as the lid needs a firm hand to close properly.My boot lock has been repaired took around an hour to fix. As for the posts re sticking back doors i have sprayed a thin film of silicone spray around the rubbers and the problem has been solved. Mine was only slight if the door hadnt been opened for 4-5 days. The silicone is water resistant and will stay on there for months at a time. Had a similar problem on my punto so i know in the long term it works a treat!
How confusing, and annoying. Why can't it just have one button that opens everything with one press and locks everything with a second press? Total simplicity.
Because any Tom Dick and Harry can then get into the rest of your car if its only the boot you want to get into, and the same applies to getting into the boot if its only the car you want to get into.
And when did that ever happen, outside a war zone that is? I can't remember ever unlocking my car and having people flock to get in with me.
And as for keyless entry: no thanks, it creates more problems than it solves.
... such as? It simply avoids the need for you to fish for the key in your pocket and press this button on it, you press button on the door, otherwise it works the same. Very useful in the rain or when you have hands full.And as for keyless entry: no thanks, it creates more problems than it solves.
