Removing the coils
With the engine cover off, access to the coils is easy. If you are changing the coils, remove the electrical connectors - lift the black tab, pull the yellow bit outwards and remove the connector.
As I was only changing the plugs, I left the coils connected to the loom as having no dexterity or patience would result in one of them being broken.
Remove the bolt of top of each coil with a 10mm socket.
Pull out the coils, they're just rubber gripping onto the spark plugs so a good tug will free them up.
