Reassembly
Put the coils back onto the spark plugs - push them down and tighten up the bolt with the 10mm socket.
If you removed the coils, replace the electrical connector ensuring you push the yellow clip back in.
Put the engine cover back on:
I find it easier to push the air hose back on first before locating it in the 'lug' at the back of the engine. Put the 3 x 10mm bolts back in to secure the engine cover then make sure to push the air intake pipe on fully. You should feel it 'bump' over the ridges on the engine cover, when it's fully seated there should be barely enough space to get the pliers wide enough to tighten the clip. If you don't push the air hose on fully it could pop off under full load/acceleration resulting in a pant-wetting bang (go on, ask me how I know...).
Either fasten up the Clic-R clip or replace with a 75mm jubilee clip.
Job jobbed.
