I've made this guide on how to remove the aerial on the seicento.
Hope this comes in handy
Step 1 :
Flick out interior light and completely disconnect and remove it.
Step 2 :
Then unscrew and remove both rear view mirror.
2 gold screws holding the roof lining then the 3 black holding the mirror.
Once you've done this wiggle and pull it out and pull out the pieces of sponge
that go either side of the mirror and put these to one side.
Step 1 :
Step 2 :
Seicento roof aerial removal page 2
Step 3:
Now remove both sun visors. Just the 2 screws and they'll come straight off.
Step 4:
Once thats all done you will have the access needed to
get to the securing nut that's holding onto the aerial base.
You will be able to pull the roof lining down enough to get to the nut
with your tool of preference.
Pull the roof lining down and hold with one hand so you can get a look at
the nut and see where your working and to get the tool in to place,
Best position is to side at the edge of the seat as if your looking towards the
back of the car but obviously looking at the nut location above the roof lining.
Using a 10mm spanner or rachet tool whatever suits you,i got better access with
the spanner undo the nut till it's slack enough then you can get your hand up and undo it the rest and it will come away from the aerial base as it's connected to the end of the radio wire so should come away quite easily.
Go to outside of car and you should be able to lift the aerial straight off.
Congrats you've removed your aerial
Refitting is the reversal of the guide,if you struggle to get the nut back on
the aerial base then ask someone to lend a hand to hold it down from the
outside so you can screw it on from the inside.
Also when putting the rear view mirror back in
remember to sqaush the sponge pieces back in at each side of it.
