seicento interior light change
Step 3:
Time to fit your new bulb.Note the size difference that when refitting you may have
to bend the metal holding prong out for a tighter fit pictured with yellow arrow pointing to it.
Also when bulb is fitted test it first before putting everything back together as
the bulb i put in only worked when connected one way.
The type of bulb you are fitting is a festoon bulb.
Step 4:
Position metal cover plate over bulb and push into place,reconnect white and black wires,put the light back up to the space it came out of feeding the wiring back into the ceiling and give it a good push and it will pop back into place.
Now checkout your new interior lighting handy work
Before and after
