[FONT="]Quick guide with a few pictures on taking front door trims off[/FONT]
[FONT="]first take the two cover trims off the latch side od the trim panel off there will be two Philips head screws underneath remove them both[/FONT]
https://www.fiatforum.com/attachment.php?attachmentid=204045&stc=1&d=1572007715
[FONT="]the take the rubber bottom out of the door handle area and there will be a hex head bolt under to remove then life the handle/window switch assembly out and disconnect the wiring plug and place safely to one side
[/FONT]
[FONT="]
[/FONT]
https://www.fiatforum.com/attachment.php?attachmentid=204046&stc=1&d=1572007715
[FONT="]Then behind the door latch release handle there’s a small cover panel that need to be taken out i used a small pick type tool to pull it out[/FONT]
[FONT="]Again there’s a small hex bolt to be removed[/FONT]
[FONT="]
[/FONT]
https://www.fiatforum.com/attachment.php?attachmentid=204047&stc=1&d=1572007715
[FONT="]with the fixings out of way there’s just a few plastic press stud type fixing on the bottom half of the door so get you hand underneath the bottom corner and give it a sharp tug then work your way around until they have all been released [/FONT]
forgot to take pic of this part
[FONT="]Finally with the bottom fixing removed give the bottom of the panel a knock upwards to un hook the top from the window area and finally the whole panel should then be able to be lifted up[/FONT]
[FONT="]
[/FONT]
[FONT="]https://www.fiatforum.com/attachment.php?attachmentid=204048&stc=1&d=1572007715
[/FONT]
[/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[/FONT]
