Tools required
The required
- Cotton buds
- Some sort of oil, bearing oil, wd40, 3in1 anything will work really, if you can apply via a straw it makes this job 10x easier!
- Different punto's have different fixings's I've seen Phillips and small bolts holding these in, so you need to investigate first really
I also used some contact cleaner - it just helps with removing muck - yuck and grime, not required but i had it to hand
