Removal of fuse Box
Use flat bladed screwdriver to open lid of fuse box. Use 10 mm socket to loosen nut inside fuse box. Remove nut then you can lift off the heavy red power lead. The fuse box is mounted in a metal cradle/bracket. Prise the front edge of cradle to release a tiny plastic square that stops the fuse box from rotating. You can then rotate the box through 90 degrees. You can then see three big connectors on the bottom of the fuse box. Remove these and you can lift the fuse box out.
