refitting the other parts
- refit the lower cam belt cover and bolt.
- refit the top cambelt cover ensuring its correctly aligned and all wiring is safely clipped in place.
- if removed refit the headlight
- refit the expansion tank.
- refit the wheel arch liner and lower engine cover.
- refit the drivers side wheel and tighten the bolts
- lift the car on the jack and remove the axle stand
- lower the car to the ground.
- torque the wheel bolts to specified nm
- reconnect the battery
fire her up and check the cars starting/running as expected. if it wont start or runs rough then re check the timing marks are aligned correctly but remember the engine may run a bit rough as the ECU relearns its perameters.
any torque figures needed can be found in the FAQ
