Comment
Guide Tools Search this Guide
Adding A Pre-Out RCA Connection
With or without an exisiting factory sub.
captain chaos
04-09-2007
<font size="3">This guide explains how to use your existing (If you have a factory sub) subs wiring loom, to add a pre-amp RCA connection.</font><br />
<br />
If you dont have an exisiting sub you can use your rear speakers connection by either taking the car to bits to get to the speakers
Old 29-06-2013   #15
col-blue has donated!
Re: Adding A Pre-Out RCA Connection
Just looked in back of my punto 2012 one lead is there which is good but there is twice as many cables and different plug.
Punto 1.4 multiair turbo lounge.
col-blue is offline Reply With Quote Quote
Old 29-06-2013   #16
Quote Originally Posted by col-blue View Post
whack a picture up mate, lets see what your looking at, also if you can get the HU out and take a pic of the back of that, if all else fails you may be able to go from the HU instead
GRANDE PUNTO 1.2
THE BLUE THUMPING UFO
Wozzy2010 is offline Reply With Quote Quote
Old 30-06-2013   #17
Will get picture up soon there is 13 wires I think. Found out what two are 12v and earth so left them in plug still. Tried every wire on speaker nothing. Also have fuse in place for the hifi system including amp. My guess the wires stop where every the amp would be in the car any one know where the amp would be fitted in a punto then can have a look from there.
Old 03-07-2013   #18
Hmmm this seems a bit odd, i have an 07 grande punto and i just wired mine up to the back of the head unit using the RCA converter then ran RCA's to the rear of the car. do you have a factory sub installed already and just want to get a better sub? because if you dont have a factory sub then i strongly recommend just going straight from the head unit. hope this helps
GRANDE PUNTO 1.2
Old 17-08-2013   #19
matt89 has donated!
I'm so confused when it comes to subs. I have a factory fitted sub in my GP and i have an 'active' sub from my previous car. How do i wire up my sub? do i only splice into the existing cables like the guide shows using this:Click image for larger version
and then use this to eliminate the high level frequency:Click image for larger version
OR
on the rear of my 'active' sub i have this input panel:Click image for larger version
with this high input cable:Click image for larger version
Any ideas? Thank you everyone!
matt89 is offline Reply With Quote Quote
Old 18-08-2013   #20
Quote Originally Posted by matt89 View Post
I'm so confused when it comes to subs. I have a factory fitted sub in my GP and i have an 'active' sub from my previous car. How do i wire up my sub? do i only splice into the existing cables like the guide shows using this:Attachment 122703
and then use this to eliminate the high level frequency:Attachment 122704
OR
on the rear of my 'active' sub i have this input panel:Attachment 122705
with this high input cable:Attachment 122706
Hi mate
Ok so i did exactly the same as you well near enough anyway, i had the RCA converter (the first picture) and basically spliced that directly into the back of the headunit as i didnt have a stock subwoofer, however if you use this guide you should get the end result but your RCA outputs will be in the boot as appose to the front which is where mine was. Im not too sure about how the high level thing works but on the active sub should be a frequency crossover on it already?
Anyway with regards to the high level input (the last picture) stay away from that as it will give crap sound, all you need is a set of RCA cables and run it from the RCA converter right to the low level input on the subwoofer and jobs a gooden
hope this helps bud, if not give me a message and i can try help you out a bit more
Thanks matt89 thanked for this post
GRANDE PUNTO 1.2
Old 18-08-2013   #21
matt89 has donated!
Quote Originally Posted by Wozzy2010 View Post
Hi mate
I spent 3 hours this afternoon splicing and cutting and taping my RCA filter and level line converter in the boot off the factory sub feed and then plugged into my sub. Main problem was getting the power into the sub but figured out a different route to most people but thank you for the help! (I've also heard high level inputs are **** but good to have it confirmed!)
Old 23-09-2019   #22
Ive just got hold of a factory sub (For the boot) in my 2006 punto. How can i wire it up? I cannot find the wiring loom for it online anywhere.
thanks
ABROWNE is offline Reply With Quote Quote
Comment
Search this Guide:
(T) 1.6 loose connection message [rpm sensor] D-Stilo Stilo 35 01-06-2007 14:31
(G) Adding Horsepower to My Bravo cghorayeb Bravo / Brava 40 25-09-2006 20:51
Help with internet connection sharing (ICS) in windows xp Bushboy Computing 7 05-05-2006 01:26
(T) Wire connection lewma Cinquecento / Seicento 13 09-12-2004 14:47
