- Aug 23, 2007
- 551
- 93
About 2 months ago i noticed that the car had problems with the rear right wheel brakes, the car wouldn't brake well the first few times, and it seemed like only the rear right brake was working. Okay, so we changed the brake fluid, bleeded the system and it was better. It seemed like the brake only braked periodically, or like it was braking half the wheel rotation and not the other half. My dad went to the garage and they changed our rear brake pads. After that, the condition worsened and it started squealing, squaking, screaming when braking, probably depending on the temperature.
So today i jacked up the car and disassembled the brake. It seems to me like the drum is warped. I'll replace it, but i'd still like to know what could have caused that? It's quite a piece of steel, imagine the force needed to do that. Thermal expansion/contraction?
Oh, also a good piece of advice for everyone doing something similar. It is usually a good idea to lift the handbrake when jacking up the car, but not when you want to remove the rear brakes, because you can't do it while the rear brakes are under pressure.
