Dear all,
i´m new to the forum and searching for some help as my Cinque is driving me mad.
i´m spannering since 30y, but mainly on carburated historic cars.
around 1y ago i purchased a Cinque 900 for my mothers caregiver ...i wanted a simple car without too much electronic, no electric windows, no power-steering , no aircon, no cambelt to change etc.... so i deciced for the "oldschool" pushrod engined 900. the car has original 40.000km, is rustfree and besides some dents in really good condition.
so far so good until recently:
one morning the car did not start anymore, it was running faultless b4:
starter motor turns over the engine as fast as usual, i have spark, i have fuel up to the throttle-body ( & each time you switch igntion to ON, you can hear the fuel-pump running / priming). but the injector does not inject any fuel during engine-cranking.
thats easy i thought...i will buy a new injector and thats it.
Nope it wasn´t, the new injector, as well as 2 used ones (from collegues) show the same problem.
on one PIN of the injector i can measure constant Voltage, once the ignition is ON. so the injector must be triggered by the Minus i guess?
if i spray brake-cleaner into the thottle-body the car starts straight away...sometimes it only runs until the brake-cleaner has burnt away , sometimes it keeps running and the injector works as it should.....but after 1 or 2 minutes, the engine dies again...sometimes it restarts...sometimes not.
if it runs and i move / bent / wiggle on the wiring-loom it remains running...the loom is original, not messed around with, no sings of marten damage / bites.
with brake-cleaner it ALWAYS starts straight away.
i can simulate this fault with 2 ECU´s (1 with immobilizer, 1 without)
for peace in mind i also changed the crank-sensor....obviously the problem remained (as i always had spark)
i also used a starter cable to connect battery minus with the engine-block...just to exclude an earth problem....problem remained.
meanwhile i´m lost. it looks like my injector sometimes get tiggered and sometimes not. but as far as i understand this basic-injection system , during start all the other sensors are not responsible for the injector to open at all?
do you have any ideas?
