OK so dismssing faulty relay and switch
"when ign is switched on and wipers aren't parked they will start at turn of key" =normal
"if parked they stay put till stalk moved" = normal
"put tester on the block put wipers on and theres intermittent power showing on meter at all settings on stalk"
"Intermittent" as in erratic or regular on off like a relay going? You've said you hear a relay going on and off in time with the power going on and off, which relay is it? The main wiper relay or the one in the switch?
Have you found C10 earth and made sure it's got cood contact?
With a multimeter- power off - check resistance of the earth from the motor to any good earth- should be near zero
Which wire are you testing for power at the wiper mpotor? One of the wires at the wiper motor WILL show power on and off as the wiper spindle rotates. That's the park switch
