Technical wiper assembly mounting
McAllister27
Restoring 1970 Fiat 500.
Must mount restored wiper assembly, however did not personally remove so have no idea how to reinstall. What is required to attach motor bracket to "firewall"?
Cannot find clear picture of assembly.
Many thanks
bob
Hi Bob
Here are some shots of my wiper assembly when removed as part of the rebuild. You can see the two holes at the end of the plate, these locate on the firewall studs and the wiper arm base has the through threaded mounting for the actual wipers in the central and end of link rod positions. These are held by a large nuts. Note this is a RHD set up for my car, the fixings are just reversed for LHD. I don't have a layout of the fit up just the parts pictures I took when I stripped the car.
Hope this helps
Hugh Jarce :cool:
