Technical Correct order of parts of the 126 / 500R engine mount
smart51
Established member
Birmingham
Can anyone tell me the correct order and orientation of the parts of the Fiat 126 / 500R engine mount? I wonder if mine has been put back wrong at some time in the past. I have a new one on order and would like to assemble it correctly.
I've finally found a video that goes most of the way there. It doesn't explain where the plastic (on mine metal) dish goes. Mine is in the bottom rubber between the engine plate and the rear cross member.
This is from the Autobooks Fiat 126 manual.
thanks @fiat500. What is the piece beneath the top rubber/item 22? Is it the small metal dish that I have?
I have only had engines dangling on the original type of mounting, so I can't confirm anything from first hand experience. But I have some engines in the garage that came with these mountings, (or part of them), still attched. I'll look tomorroow, but you won't need to wait that long as I'm sure that someone will pipe up soon.
