Suprisingly it's the rears that seem to do most of the work in the Tipo based cars. I'd have said the difference in feeling between changing the front vs rear shocks is about 70/30.
either he is retarded, or he was trying to get out of doing the other side.steely said they dont need to be done in pairs!!
Retarded!, ha far from it lets not forget i used to repair dampers for industry not poxy car dampers but hydraulic type,if it wasnt safe i would of done it, end of,right Damplers....... (correct term kay not shocks ) simplified, dampers are a light base oil which shift between two cylinders, through a pin hole,. its the springs that are detrimental about being replace in pairs,
everyone jumps on the replace both at the same time band wagon... plenty that can talk the talk but not walk it!
rant over
do it yourself next time kay
cheers for that! made me re read it and see all the typos! hahaPwned
if one has gone other is near end of life, so may as well do that too
Retarded!, ha far from it lets not forget I used to repair dampers for industry not poxy car dampers but hydraulic type,If it wasn't safe I wouldn't of done it, end of
.....right....... Dampers....... (correct term kay not shocks )
.....simplified, dampers are a light base oil which shift between two cylinders, through a pin hole,.
i've walked the walk dozens of times in the last dozen years. while you were still making fart jokes at school i was doing stupid things like chopping springs and only changing the shocks on one side. i've made the mistakes and seen the results plenty of times.its the springs that are detrimental about being replaced in pairs Not Dampers!
Retarded!, ha far from it lets not forget I used to repair dampers for industry not poxy car dampers but hydraulic type,If it wasn't safe I wouldn't of done it, end of.....right....... Dampers....... (correct term kay not shocks ) simplified, dampers are a light base oil which shift between two cylinders, through a pin hole,. its the springs that are detrimental about being replaced in pairs Not Dampers!
rant over
it isnt safe, read any manual, or ask any qualifed mechanic, or use past experience (if you can have much at your age), or even apply some basic common sense ffs.
dampers are shock absorders, shock is an abbreviation of shock absorber. both terms are correct, but i agree the technical name is damper.
they arent hydraulic, its nitrogen gas in this application. all bravos have gas shocks on the front, that is why leaks are more difficult to detect, you dont get a wet patch.
i've walked the walk dozen of times in the last decade. while you were still making fart jokes at school i was doing stupid things like chopping springs and only changing the shocks on one side. i've made the mistakes and seen the results plenty of times.
bound and rebound are controlled by the dampers, nothing else only the dampers. the springs control ride height, but only the dampers control the 'bouncing' of those springs.
bound and rebound both have a huge impact on cornering, especially stability. if one side if different to the other it has a negative impact on handling, not least in how easily you can predict the way the car behaves, but also because any movement will transfer to the weaker side, which usually drags the car to one side.
lets imagine you hit a bump going round a fast corner, with even damping you'd have stabilty, with uneven damping you'd have a lurch to one side. that difference can mean the difference between staying on the road and leaving it.
have you even driven a car with uneven damping before?
i thought you were lazy and the retarded bit was a joke, but now i'm wondering.
:yeahthat:it isnt safe, read any manual, or ask any qualifed mechanic, or use past experience or even apply some basic common sense.
we are all on this forum because of the same interests, cars,, fiats and so on,,, if youve got a dig with me , gladly say it stood in front of me,,,, not over the net,,,,
who's ben?
shocks are replaced now, just waiting for the new bolts to get the top mounts attached and then i can get the wheels back on and drive the thing!
as if its taken me a WEEK to change bloody shockers haha
