Hi there
how is everyone doing? I have a fiat punto mk2 2004, 8v.
I've got an issue, which I noticed 3 months ago. As I'm driving at high speeds, the car will begin to do some sort of whirling noise from the drivers side of the engine bay and as I slow down, the whirling noise starts to slowly fade away until it's gone. I changed the timing belt, and I didn't hear anything for possibly 1month, and now it's back. It sounds like a tiny horn but at the same time a fan spinning?
The timing belt, water pump and the alternator belt have all been replaced and are brand new. The alternator belt was changed maybe 7-8months ago and the timing and water pump only last month, or two.
Just to note this noise isn't always there but sometimes. Recently it's appeared quite often.
I've read somewhere, it may be the steering pump, or the wheels not on properly. I believe the wheels on perfectly fine? Regarding the steering pump, I do occasionally get the red steering wheel symbol on the dashboard and all I do is turn the car off and turn it on again. I've seen some people on youtube just take the fuse out and then turn the engine on and then put the steering pump fuse back in. Someone else said change the relay fuses and it'll solve it for two years. I also saw someone say fill it up, but how would I do that? and where would i remove the old liquid?
I also feel like it could be the alternator? The problem is I can't actually identify it because it happens at specific speeds. Last week, I heard a louder noise at 10mph. It weren't a metal on metal sound, neither anything sounding like it was hitting it just seemed like a weird screaming noise? But this sounded differently to the whirling noise.
I honestly don't know what it could be.
