smart51
Established member
This weekend I have fitted a new Zelmot distributor, and also a new length of fuel between the fuel pump and the copper pipe coming in to the engine bay. The car starts straight away off the key, even if it has been sat overnight. All good.
it doesn't come off the choke well though, even when warmed up. A brief blip of the throttle from idle will make the engine start to die. More so if the choke is off. It is massively down on power at all revs and will barely move under its own steam. It sounds to me like fuel starvation. Turning the fuel mixture further out has no effect.
I've checked that the idle mixture setting, points gap and spark timing haven't changed. They're all good. What's the most likely culprit? Where should I start to look for this one?
