What is he grinding? Isn't that a plastic undertray
I use a grinder for my coffeeIf you dont use a grinder then it's not a proper repair job
Looks like he’s cutting the under tray so maybe rather than take it off they just cut it to drain the oilLooking at some used cars in a quiet moment this is one of the 40 pictures or so of a C3 Aircross.
Which maintenance operation is this?View attachment 448884
What straight through the sump, that will speed it up!!!Looks like he’s cutting the under tray so maybe rather than take it off they just cut it to drain the oil![]()
Single use engine, use once and throw away.Well that explains the sparks.
Single use sump, no plug.
Yep, pretty standard for main dealer serviceWhat straight through the sump, that will speed it up!!!![]()
However I would point out, in the black and white I wasn't "feeding" just fat![]()
The one in the last photo is now the three year old who was sat in the puddle with the dog on the weekend, before doing her "pull ups" on the bars.My wife still ribs me now about when my lad was tiny, it was 3am and he was very much awake and he went to er latch on.
The one in the last photo is now the three year old who was sat in the puddle with the dog on the weekend, before doing her "pull ups" on the bars.![]()
Was looking at your Ammeter Jock, just to be a "snob" I have the slightly later version that reads 400amps and 60amps so handy for laying across a starter lead for cranking or in the other groove charging rate on battery lead. Still Crypton quality though.Too right Mike. Thought I was "wise" enough to avoid - but it seems not! Looking on the bright side though, he seems a nice chap and has lots of "useful" contacts. Now, if I can just manage not to wreck his wife's car!
I used to do the "Rock a bye Baby " bit in my arms to wind them when they were too oldAll good fun at some point they will be too old for this sort of thing...so very much make the most of it.
At the weekend was out with a lad I've known since we both went to primary school together. Him and his wife have a just had a little girl.
Obviously my nearly 6 year old saw the attention the baby was getting and decided he'd have a bit of that.
So there's now a photo in existence of me and him standing with our respective children, him holding is one month old in the crook of his arm as you do...and me standing there holding my son in the crook of my arm.
Amusingly he's not a big bloke (I'm not but he's 5'5) so it's nearly in scale.
Always a source of great amusement when, in an action movie, someone is using a grinder of some sort and when you look closely it's obvious they're doing it purely for the spectacular sparks!If you dont use a grinder then it's not a proper repair job
They have obviously never set fire to the pile of oily rags in the corner, or in my case cotton overalls while still wearing them.Always a source of great amusement when, in an action movie, someone is using a grinder of some sort and when you look closely it's obvious they're doing it purely for the spectacular sparks!
Ok show off! nice bit of kit and analogue too, I like it! Well I know you need digital on so much electronic stuff these days but there's something "nice" about watching a needle swinging across the scale, don't you think?Was looking at your Ammeter Jock, just to be a "snob" I have the slightly later version that reads 400amps and 60amps so handy for laying across a starter lead for cranking or in the other groove charging rate on battery lead. Still Crypton quality though.![]()
Up here in "salty road land" it was the step in front of the rear subframe which rusted horrendously on the 1100 range. I've taken a few subframes out of those so the welder had access for repairs. Methanol antifreeze? we used to test it by dipping a finger in and sucking it. If it tasted nice and sweet then there was probably enough concentration! In later years I found out how poisonous it is! probably explains a lot about the way I behave? Never tried setting fire to or tasting hydrolastic fluid though.They have obviously never set fire to the pile of oily rags in the corner, or in my case cotton overalls while still wearing them.
Thinking back welding Morris 1100s and the Hydrolastic fluid "methanol antifreeze?![]()
Yes I have dropped subframes and welded a few of those back panels. I have tasted antifreeze, but more to see if it was antifreeze or something else dripping under cars.Up here in "salty road land" it was the step in front of the rear subframe which rusted horrendously on the 1100 range. I've taken a few subframes out of those so the welder had access for repairs. Methanol antifreeze? we used to test it by dipping a finger in and sucking it. If it tasted nice and sweet then there was probably enough concentration! In later years I found out how poisonous it is! probably explains a lot about the way I behave? Never tried setting fire to or tasting hydrolastic fluid though.
