What's made you smile today?
Jock if you want to.. Put the heating on 👍
Current climatics are 'damp'. So that will also make you both feel colder
I am running my GCH in the day currently..(morning and evening) 1890's stone hasn't had/needed heat since April..
So I am 'drying it out' before the temperatures drop
Edit. Oops! just realized this is the "smiley" thread. I probably should have posted this in the "grumpy" thread, shouldn't I?
You have to laugh at it all Jock.. 🙂
Our GP want the same "ring in the morning" approach.. But you can go down there and get a Same Day if you go at opening time
Or ring in the afternoon.. And get a "Telephone Appt".. for the coming days
The GP will have a 5 minute discussion.. Then ask if you can "come on down" today
So at least you have a chance of seeing a GP in a week or so.
To be frank I think it's similar throughout mainland UK.. 🤔
People grumble.. But they do ask if its Urgent when booking..
And I have been seen in an hour where necessary 👍
we decided to trigger the central heating timer to on for the first time this autumn. Turning the central heating on for the first time after a period of inactivity is always a bit of a stressful moment as our system is prone to air locking if not used for some time and doesn't always oblige.
I leave our heating in all year round. Thermostat and times are reduced in summer, but always let it run every day and it's never had a problem like that in 20+ years.
The first use, last night, will have put a lot of its heat into the house structure. There will be loss overnight, but perhaps less than you put in.
In 1987, we bought a small house with storage heaters as its only heating. Once we'd got the things hot, after a few days, we had a warm house, that stayed warm 24/7. Having grown up in a cold house, with ice on the inside of the windows on winter mornings, this was bliss. Even better when we replaced the storage heaters with new ones, took us a while to get the temp down again.
It occurs to me, that the house itself becomes part of the heat storage. With the heating on all the time, the structure becomes warm, walls, and furniture are all comfortable to touch. With friends, who have their heating on twice a day, it seems to heat the air, but everything else stays cool, so sitting down on the sofa takes a lot of heat out of you.
From this, our behaviour changed. Spring and Autumn we might have the heating on twice a day, but once it gets chilly, the heating goes on, and stays on 24/7. Theoretically, we are only inputting the amount of heat lost by the house, which is probably frightening, as it is poorly built. But even at today's energy prices, adding heat is still cheaper than rebuilding the house.
Thanks PB. Food for thought here I think. Like you I grew up in draughty old houses with single pane wood framed windows which frosted up even on the inside when the cold came. Our second house, the one we bought when we returned to Scotland, was a timber frame bungalow in a small country village on an exposed hillside. The village had no mains gas so we had a storage radiator in the hall - core of the house - and one in our bedroom. They really didn't heat the house properly and cost a small fortune to run. The next house was a new build end terrace with cavity walls - brick exterior and block - in a quite sheltered location not far from where we are just now and it had full gas central heating. Compared to now the gas was cheap and we got used to being toasty warm.
Then our youngest decided to join "our gang" and that house wasn't big enough so we moved to our present abode (about 40 years ago which we bought new. Watched it being built actually.) It's detached with brick and block cavity walls again but it's also got heat retaining cladding inside the cavity. This is quite interesting in that the outside surfaces are all brick then there's the cavity. Next is the cladding which is a sheet material held to the inner blockwork with clips which consist of large diameter washers nailed through to the blockwork. The cladding itself consists of a thick bright reflective foil then a polystyrene (or looks like polystyrene but probably isn't because it doesn't burn - I tried some) then a sheet of thick black card. Can't remember if the reflective sheet faces inward against the blockwork or outward towards the cavity. Here's some pictures of it:
As you can see that's actually an offcut. The wastage when the houses were being built was horrific. The brickies didn't seem to take on the concept of saving the offcuts to patch into odd corners etc. Once a sheet had been cut any left over just went into the skips. I salvaged enough, by creeping around after dark, to line the inside of my garage door:
Which has made an enormous difference to how warm the garage is in winter. The material is very interesting, if you put your palm flat against it then initially it feels very cold - whatever the ambient is I suppose? - but very quickly, within seconds, it feels really warm, I suppose because the heat of your hand can't leach away into the material?
Anyway, the result is that the house generally is very good at retaining heat. It costs less, by a noticeable margin, than our previous 3 bedroom end terrace. I'm pretty sure that our new, heat reflecting, completely draught free, .double glazing will save us a wee bit more too.
Now, PB, after thinking about what you were saying about the house becoming "heat soaked". That might work rather well with all the insulating sheeting in our walls. In effect the house is "wrapped" in these sheets. I've also doubled the original loft insulation - it's now roughly twice the depth of the original ceiling rafters. I think I might try running the heating permanently on for 3 days or so - probably, as you say, it'll need a couple of days to warm everything up - and then, maybe on the 4th day, record how much gas is used.
I may have a bit of a battle convincing Mrs J, as we had a gas fire put into the living room a few years ago:
Which keeps the living room very nice and cosy for well under £1 a day in gas. It's both radiant and convection and only needs to be on for about one hour every two and a half to three hours with it being on the pilot in between which keeps it warm. D'you like Mrs J's "natty" footwear resting on the coffee table? sorry for all the grandchildren's clutter.
Thanks too for your encouragement Charlie.
The house move is nearly done (except to clean the old house) and
I HAVE A GARAGE !!
It’s only taken 40 years to have my own garage but finally there. Somewhere I can put my own tools and know where I left them and know they will still be there when I go back.
As there is access to the garage from inside the house, the plan is to insulate it to make it a nicer (warmer) place to be, put some more lighting in, and I’ll be able to work on many projects in comfort without having to rush things and tidy everything away over night.
Give it 10 years and it'll be so full of junk that you cant get anything in there.
we've had the keys a week and its all ready full of crap. At the moment that's been driven by lack of proper acess to the loft to store stuff, but once I can get up there I will be moving a lot of stuff into the loft for storage and then the garage will be mine......
Also have a lot of empty boxes stored there from the new fridge, oven and other bits we ordered which we needed for the new house. they will be slowly making there way into the recycling bin over the next few weeks.
We had something similar put in with the new heating system fairly incredible compared to the old one it's officially 90% efficient when your normal open front gas fire is more like 50%.
It has unfortunately started radiator wars again though...have to take the wireless thermostat to my office. As otherwise the front room is toasty...and that knocks the heating off in the rest of the house.
To be fair heating that achieves the required temperature at all is still very much a novelty...
It took you 10 years?
It's a doube garage, and floor space is about two and a half times a normal single garage. So about 10 years to clear out everything since moving in, then another 10 years to fill again. Though we do have a clear out every few years!
Two envelopes in the post.
First for my partner, advising ofthe winter fuel payment, £500, thank you very much. I told her I'd get her a bag of coal.
Second, from Department for Works and Pensions, titled, "Get yout State Pension".
Don't mind if I do. Highlights only 3 months to go though, although one could argue a year late, as they moved the goal posts.
Yup, nearly all the Fiat/iveco/LR/L200/niva stuff gone
Always a following for obscure stuff eh!;)
Just completed 240 miles in a car I bought sight unseen from Facebook market place. A nearly 25 year old Italian car. An absolute shed, you would not believe how bad it actually is.
But it got me home without missing a beat.
So now the work begins;)
