What's made you not grumpy but not smile either today?
Partner fell out of bed this morning, around 2:30am. Got one arm tangled in the bed frame. When trying to help her, she pushes against you, so a few minutes of trying to extricate her, and my heart was racing. Called an ambulance at 2:37, it arrived at 6:35. Now that arm won't straighten, probably temporary, as there's no pain, and her one leg is struggling to support her when transferring from loo to wheelchair, having been bent under her for four hours.
Quite a few years ago, at a bowls match, one player took a swig from his tin of drink, and got a wasp to the back of the throat. Someone had to take him to A&E a bit sharpish as it swelled, threatening to suffocate him. Returned about 4 hours later, very sore, but otherwise OK. Beware opened fizzy drinks.
I'm so sorry to hear that, At least she's not in pain and I hope she gets some mobility back soon. Mrs J's Aunt - She was fiercely independent and lived alone - fell off the kitchen steps when trying to get at a high cupboard. She lay on the floor all night and was found next morning by a neighbour. We got right across to city, through rush hour traffic, before the ambulance got there. Unfortunately she never really recovered and passed away a wee while later.
The females in our family have always been prone to severe reactions. Daughter swells up something horrid if stung or even bitten by an insect and they seem to be particularly attracted to her. We can be out for a picnic and she can get multiple bites when none of the rest of us get even one! Mrs J has an intolerance to kiwi fruit, gives her an anaphylactic reaction. she had one quite mild reaction a number of years ago, then a couple of years ago she had a really bad event which nearly did her in - rushed to the hospital in an ambulance and it was touch and go! She was told then that if it happens again it'll probably kill her. Trouble with Kiwi is you can't tell if the juice is in something like a fruit salad even if you can't see a slice of the fruit itself. So she just has to avoid anything which isn't one fruit only. Pity because she really enjoyed a bit of Kiwi fruit.
Please also consider, especially if the arm and leg are on the same side, it could be a sign of a stroke/TIA, and get her checked out accordingly. I know you say its because of her arm and leg being tangled and bent under her, but at the same time this assumption could mask something more serious.
Found this interesting no one else may..
I've been expecting inlet valve cause coking at some point..it is DI after all.
However maybe not...for 2 reasons.
1. look at the position of the injector spray and the inlet valves.. the injector is near horizontal and they are quite literally in the line of fire.
2. When cruising the inlet valves are open with a fuel mixture in the cylinder on the compression stroke in Atkinson cycle operation. This reduces pumping loss..but also forces fuel mixture out of the inlet valves which will be boosted back through under normal running.
Perhaps the combination of these and lack of any active EGR might make this a DI engine that doesn't need regular cleaning..
Atkinson cycle operation is very interesting (and has various versions developed over the years - see Miller cycle for instance) As you mention, It's basically a way of reducing pumping losses by keeping the inlet valve open well past BDC thus allowing some of the air which was drawn into the cylinder during the induction stroke to be forced back into the inlets. If you do this then there's not so much resistance on the piston as it compresses the air on it's upward stroke which means improvements in fuel economy may be possible. I learned about it many years ago at college, so it's been known for many years, but it takes variable valve designs to make it work as it needs to go back to normal valve timing for situations where power is required. I first really got interested in it when I was going to buy a Honda Civic estate with the 1.8 litre i-VTEC engine back in 2016. Unlike other Honda VTEC engines, this is not a performance engine - but still quite powerful enough - which utilizes the famous VTEC system of valve actuation to achieve a form of Atkinson operation. It's a very interesting engine and I was "desolate" when we found it was impossible for Mrs J achieve a satisfactory driving position - we bought the Ibiza instead. The fact that this form of operation pushes gasses from the cylinder back into the inlet during the compression stroke means that, depending on injector timing, there may be the possibility of allowing fuel to reach the back side of the inlet valves which might? reduce inlet valve/tract carbon fouling?
Just trimming this down, the injector fires during the induction phase... however the inlet valves remain open during compression phase so you would think the inlet valves come into contact with neat fuel during induction and fuel/Air mixture in the compression phase during Atkinson operation.
I actually did consider the Honda the 1.8 produces very similar real world performance to the 1.2 and they are similar money. 2 things stopped me, 1 the Toyota came up first and 2 the Toyota is a higher torque engine at official figures and the Torque peak is 2500 rpm lower...at dyno figures it's a much higher torque engine. Official figures 116hp Dyno just short of 130, official torque 185nm Dyno 218nm, the discrepancy does at least explain why it feels little slower than the C3 which is much lighter.
After the Mazda I was a bit reticent to have another NA VVT petrol screamer as a family car especially in an estate that you'll load up. It's fun going full VTEC yo on your own but in reality 4 or 5 up and a boot full of crap needing to get up in the revs to get it up and away gets wearing. That if you're pegging it to 4 or 5k up hills to maintain speed before a shift your passengers tend to think you're an arse, while the turbo can maintain the speed without the obvious display of effort.
After the Mazda I was a bit reticent to have another NA petrol screamer as a family car especially in an estate that you'll load up. It's fun going full VTEC yo on your own but in reality 4 or 5 up and a boot full of crap needing to get up in the revs to get it up and away gets wearing. That if you're pegging it to 4 or 5k up hills to maintain speed before a shift your passengers tend to think you're an arse, while the turbo can maintain the speed without the obvious display of effort.
Absolutely agree re N/A vs Turbo. When I started looking for a replacement for the Ibiza - with it's small but powerful for it's size, turbo DI petrol engine - I pretty much convinced myself that I wanted a Jazz. I'd been looking after my daughter in law's Jazz and was very impressed by the way it was put together and general quality. However, when I actually drove one I realized how much more I liked the "lazy" low rev punch from the turbo engine. I took quite an extended drive in the jazz and it was quite nice cruising along on country roads and in town but I disliked the way you had to build speed and really wind it up before overtaking. The Civic, being a larger capacity engine, was much better in this respect, but still needed to be above about 4,000 rpm to really get up and go. I liked the car so much I could have lived with that though.
For me I was just considering my use case which is if I'm on my own I'll be in the Citroën, if I'm in the Toyota it'll be loaded up. So while given my history I like to work for performance the situation is it's not correct for this application.
Odd thing to say I didn't particularly consider liking the car when I bought it, it was the right price, right age, right condition body wise and interior and the right spec and not offensive to drive.
It wasn't however particularly good just liveable, I didn't particularly care given the plan was to beat it to death if anything if you're planning to kill a car then not liking it much is a good start.
Being me though I ended up spending time and effort going through getting it to my liking and fully serviced up etc. Doing that I've realised it was pretty badly hobbled when I first got it. Mainly down to square/unbalanced budget tyres and the alignment being cross eyed. Having whackamoled the various minor issues the previous owner left me with it's a different and actually surprisingly nice car.
As a result I'm not ok with just killing it anymore which is shame but may end up being cheaper in the long run. One of those things driving another one would have probably highlighted this one needed work...but when there's usually a max of 3 for sale nationally it's not massively realistic. Also test drive was max speed 60mph on poorly surfaced country roads it only got really interesting/worrying on freshly surfaced motorway where it was obvious something was going on.
She had a visit from a specialist nurse yesterday. Spent over an hour with her, and seems happy, but is following up later in the week. Partner is brighter today, and arm movement is improving slowly.
Apple's biggest event of the year is on tonight, 6pm our time. First year watching its 'developer' conference since 2008 as an actual developer. Quite exciting!
Although... the more I delve into the world of programming the harder it gets to be on a Mac. They spent years making it work with everything and being a 'good citizen' in a world of Windows devices. All of that now ruined by the size of the company, its dominance in things like phones / watches / tablets. Now it doesn't need to be a good citizen anymore and its bottom line continues to grow.
They have these fully pre-recorded, fake feeling, videos now which was nice during the pandemic but every other company is back to real life events. Real demos and all the pressure, preparation and delivery. All the other companies are running rings around them with AI. They all offer tools that work with other devices, are flexible, usually free and open. Much easier (surprisingly) to work with. Sort of coming to appreciate that now over the 'keep buying our stuff so it works together'. It sure does work when it's all Apple, but the second you want to do something they don't like, you get a slapped wrist and you're left with something you put time into that they say is either not allowed or not supported anymore.
Time will tell...
Time will tell...
I'm an absolute dinosaur when it comes to this sort of tech. I don't understand what I'm doing a lot of the time and have only ever learnt the basics I need to know to work emails, browse the net, etc.
I've stuck with windows laptops - this is only my second device ever - mainly because they are cheap to buy compared to Apple stuff and because stuff like MES and VCDS run windows. I'm dreading buying a new laptop, which I'll be doing soon as this old one is failing. Learning a new version of windows I'm not looking forward to.
I've found to find something on par with Apple's kit, you spend more on the Windows side / Android side and still come up short in some areas / ways. But at the same time, many of these little things most people don't care about or value something else (maybe out of necessity) that Apple just backwardly refuses to allow or work well with
Windows 11 isn't too bad, you can pretty much change it around on day one to be like Windows 10 if that's what you're on. I must admit, their 'Copilot' AI - whether you have a conversation with it or type - is probably more than capable of talking you through absolutely everything you'd need to know. If you invest a little time into anything, I'd say ask someone to show you how to trigger it and talk to it as it'll be baked right into Windows 11.
Just built up a very, very long list of things to be studying over summer now. God bless YouTube, and the people who upload entire actual courses sometimes 24+ hours long into the world for free. There's a lot of doom and gloom in the news about the world at the minute, but we're doing something right when knowledge has become nearly barrier-less to access 😁 - in fairness, look at all the fantastic info and friends we've all made on Fiat Forum since the early 2000s, and videos on YouTube explaining car repairs, tools, problems etc. lots to celebrate
Thanks. Yes I'm on windows 10 just now so the new one will be windows 11. I may pop into our local community centre once I've bought it as there's a very nice computer person there who offers free advice/guidance in one hourly sessions per week - you get one on one with him if you book a session.
Its a bit hot.
Dragged out the large pedestal fan, dusted it off, plugged it in and turned on to the slowest setting. As usual, it shuddered a little as the fan started turning, and quickly got up to speed. About 20 seconds later, there's a clang, and a lot of vibration. One fan blade has succumbed to age, and fallen off, breaking into lots of tiny pieces, most caught inside the mesh guard.
Oh, well, off downstairs to collect the small desk fan. Picked it up, and the base fell off. More age-related deterioration. In the garage is another desk fan, no, same issue.
The trip to the tip was nice, with the aircon blowing fiercely.
Found a website called 'only fans', but it is a misnomer, no fans for sale. Only likely to make you hotter, not cooler.
Its a bit hot.
I bit the bullet in the really hot year. 2022?. I bought a 'portable' air con / dehumidfier / heater thing. Actually its definitely not portable.... It was £500 but boy has it ben appreciated. Its a pleasant 23C in the sitting room. Seems to consume about 500watts in use. As its only used on hot days solar power pays for it. Last 3 months solar panels have earned £90 on top of 70kwhrs diverted into hot water and 1400 units of power consumed. We do have an ideal roof for solar, but its seems to be worth having. I think it will have paid us back by 7.5 years. So we are nearly halfway to covering its cost.
Its a bit hot.
Only fans…I guess your bp went up a bit 😉
I am guessing that website was a bit like one my ex wife found when looking for French Skipping I think for my daughters,which she thought involved jumping over strings in the play ground ? That wasn't what she found though.!!!;););)
The funniest thing I found about 'Only Fans' is how when you went on it a few years back, before a log in, the front page was like some example of an older lady, who recorded her cooking videos and tips ... and the premise was OnlyFans was for people like this - you know, good honest humble wholesome hobbies shared for some reason privately. As if lol
The real 'Only Fans' is why there's girls who were in my class, not the brightest, buying their nice houses and driving Porsches - no bother to them! 👀
