What's made you not grumpy but not smile either today?
@AndyRKett
Hot side of the turbo, red pipe is down to the intercooler black pipe is cooled air coming back and heading for the inlet port.
And yes the car looks like it lives on a farm... because I'm the only who would clean it and I don't..
As I'm trying to do more cycling, not so much to get back into shape as to not get any worse, I dug out my 1990 Miyata 600GT that I rode in Paris Brest Paris way back in 1991. It's a sweet riding bike.
I took the Miyata out for a short spin yesterday, about 7 miles in some serious heat. In order to get the bike out of the garage, I had to back the Ural out. I left the Ural parked in the driveway. The ride itself was uneventful. The bike is in better shape than I am. As I'm rolling Miyata back into the garage, I smell gasoline. I look over to the Ural and fuel is leaking out the right carb. Crap. Stuck float. I hit the carb bowl a few times with a screwdriver handle to knock things about but it doesn't work this time. I go to close the petcock on the tank and it's closed. Crap, crap. So, both a stuck float and a failed petcock. The petcock is only two months old. I lightly push down on the kick start and the right cylinder is full of fuel. Crappity crap crap. So, stuck float, bad petcock, and a crankcase oil change. I was due for the oil change anyway.
I clamped the fuel lines to both carbs, drained and siphoned a liter(re)of fuel from the cylinder, pulled and cleaned the right carb, changed the oil in the engine, tranny, and final drive, replaced the plugs, and balanced the carbs. I also ordered a repair kit for the original vacuum petcock.
The most annoying thing about all this is having to do it all outside in the sun. I was baked and not in the way I would have liked.
I have an old 12.5hp V twin Briggs and Stratton three phase 415volt generator which I hadn't used for some time, dragged it out of my van to do some work on my boat. It fired up straight away but sounded awful so switched off and found all the fuel tank had drained into the sump as like an idiot I hadn't turned the stop cock off 12 months before.
Luckily an oil and filter change and right as rain;)
Not much sun over here. Cloudy with outbreaks of rain and the occasional flash of sun from behind the clouds.
Stuck floats on the old SU carbs was a common problem.
Does the pushbike have drum brakes?
Yes it does. I have a soft spot in my head for them on a bicycle.
In the days just before the start of PBP, I was riding around the Paris suburbs with some other idjits. We're flying down a steep hill in Nanterre, passing 50 mph. A stop light turned red a short distance ahead, so I grabbed two handfuls of brake lever and slid my butt over the rear wheel to keep from skidding. As a group, we managed to stop at the light. Someone said, "that it smelled like someone burned a clutch." I poured water from my bottle on the front hub and it sizzled. I said, "I think it's my brakes."
Riding the 1200km of Paris Brest Paris was a hell of an experience and I never want to do it again.
So start of August we had works to separate out the electric supply for the street.
This month our electric bill has dropped by 70 quid...yes it's August but it's not been that low for years despite no change in how we do things between July and August.
Wonder if next doors has gone up by 70 quid...🤔 Or indeed 100%
We weren't given any specific reason for the works just "they were having some problems with their electricity supply" and "like to separate them out these days".
Interesting.....
Eagle eyes!
It's Florida hot and humid here this morning. Bleah! Even Buster dog noped out on his walk.
Who am I kidding, Miami would have been cooler. Peaked at 102F with a heat index of 121F. I was glad all chores were indoors yesterday. Fifty degrees cooler this morning. It’s still fecking humid but we’re stuck with that until the thousands of acres of corn and soybeans are harvested.
Its a nice 23C here thats about 73/74 or so to you, and 56% so pleasant, but Im visiting USA east coast soon so I hope its cooler than that. Standby for the thunder storms.
We had the thunder storms last night. A lot of lightning and noise with a tiny bit of rain. Those storms usually follow in the evening on a day like yesterday.
That would be my understanding pretty much, in at the headlamp past down the passenger side of the engine, 90 degree bend to the filter then back the same way to the turbo then down to the cooler then back down the drivers side to the inlet ports.
Bonkers, but I'd assume the packaging is dictated by both the use of the engine pretty much unchanged in many models some of which have a shorter bonnet than the C3 and also shared parts with the diesel which seems to be very similar indeed.
Had a day out in a 72 plate Honda Jazz hybrid yesterday.
Initially seems pleasant enough, and the hybrid system gives it plenty of urge off the mark if you press hard enough, so quite quick at times. Handles well, goes where its pointed, adequate space inside for a small car.
Packed full of toys. Auto aircon, Lane assist, adaptive cruise, speed limiter - standard, or connected to sign recognition, auto main beam.
The speed limiter connected to sign recognition worked very well, with no missed signs, or incorrect ones, although we didn't find any side roads with angled signs, so no idea if it copes with them.
Adaptive cruise worked well, including down to zero, then off again, but does not accelerate with a right signal to facilitate overtakes, so that was a disappointment.
BUT. After 4 hours in it, it became very uncomfortable. What initially appeared to be firm seats, became planks.
So, despite all its other good points, it is a no from me.
It was lovely this afternoon, after the sweltering heat/humidity a few weeks ago 15 odd degrees and a gentle breeze was great and we walked about 6 miles...
But it's already getting chilly in the mornings and evenings.
And the daylight hours are noticeably shorter too. I like to open the bedroom window when I first wake up and just lie listening to whatever as I slowly come too. Definitely needing to pull the duvet up round my chin now though.
I only leaned against it honest!:)
