Did he make you carry them back to the freezer?Buster dog spotted two deer on our walk this morning. He made me run and my right arm is now longer than my left arm. That damn mutt can do a wheelie.
I had similar with TIGAR years ago nearly new.. 6 weeks old.. It had a slowpuncture where air tracked out through the steel,Lent the son my "spare" panda a few months ago, as he was having some problems with his car. Last weekend he told me it was feeling a bit "strange" when taking left hand corners at anything over about 20MPH.
I told him to leave it with me, and I would have a look.
So, had a look, all looked fine.
Took it for a test drive. Sure enough, very peculiar feeling on left hand bends.
Looked very closely at tyre while spinning it, and definitely some strange deformation, but without the normal strange wear pattern, or the out-of-balance feel when driving.
Not had a problem with Nokians before (unlike some of the unknown brand tyres I come across every now and then), but this one is definitely goosed.
Ah well, mystery solved, didn't have to change suspension parts in freezing weather, and had spare wheels with tyres available, so mostly good.
(The bit that looks like scuffing on the picture was where I cleaned it to photograph)
Wise advice.Never run a hand around a tyre blind, touch only what you can see.
Last resort , I am sure you are aware of is "Universal" CV boot from Motor Factors, I know the quality is nowhere as good but it would get you mobile.The saga of the knackered CV boot continues..
It was meant to be fixed today...after having the locking wheel nuts professionally removed (just argggh! I didn't lose the damn thing)...wrong part turned up as the turbo has different CVs, of course it does.
*Sad trombone* to be fair makes no odds don't need it until Thursday will happily go grab it tomorrow but at least the damn wheels are off.
It eventually got sorted... however CV still sounds a little unhappy with a little mild rotational noise remaining after being run with a split boot (joys of one car couldn't just park it until fixed).Last resort , I am sure you are aware of is "Universal" CV boot from Motor Factors, I know the quality is nowhere as good but it would get you mobile.![]()
I have my snow socks In the boot just in case, though I don’t suspect it have many instances I would use themDoes somewhat explain why I've not used my tyre socks since I stuck winter rated tyres on.
Your a signed up member of the grumpy old man club now. Proof positive.I'm starting to find I dislike these cars with lights along the whole front or rear of the car. Not sure why they annoy me.
My winter tires are now on for the 3rd season, they have done about 7 to 8000 miles. Its hard to tell from one year to the next due to the gap in time but they are a massive improvement on summer tyres both on wet and icy roads. The roads round rural Norfolk are awash with mud slurry and there are flood aplenty at the moment. All I can say is the winters feel totally secure and vastly better than the two other cars on their summer rubber. The clear lines left behind even on wringing wet roads are a clear sign they are more effective in clearing away mud and standing water. As far as I can tell they are working as well now as when new. The tread is still nearly 8mm so wear is negligable. The summer tyres are getting down and will only do another year or two. When they are worn out I shall the leave the winters on until they are worn out too. Befoore replacing anything to avoid them aging excessively.I have my snow socks In the boot just in case, though I don’t suspect it have many instances I would use them
I have summer tires which are the OEM tires the car was supplied with (obviously changed a couple of times).
We just don’t get enough snow or even ice down here to warrant buying specific tires. While you had 6 inches of snow we had cold wet rain for a few days.
All these comparisons to winter tires are all the same I should point out, they are always brand new winter tires and never tires with 5-10k on them that have been driven about for a few months or locked away between winter seasons for the compound to go hard in a garage somewhere.
I wonder how well they would perform if they were a year or so old, driven some distance and then had some period of storage like a set of winter tires may do between winter seasons?
Now far be it from me to point out that in most road conditions 4x4 is excess weight and the tyres are what makes the differenceNot much point having a 4x4 and still getting stuck.
Nah Noop doesnt do crawling andcertainly not on rocks. He doesnt really like rain..... or bumps... LOLTo be fair whatever works where you are.
I seem to remember the testing this year involved also testing them part worn when he put his video out..it's on the same channel. They drove cars in convoy to wear the tyres out.
The more expensive tyres are designed to evolve as time goes on to stay grippy as tread gauge.
Front tyre new in April done about 8k since got about 7mm on it.
You can see on the shoulders and across the breadth the sipes are nearly straight, when it was new they were but you can see a zig zag pattern under the surface.
Rear tyre, new in October 2020, used to be on the front but has been rotated, has 5mm on it and has done approx 23k miles
You can see the same sipes are absolutely not straight, they are cut to become more jagged as the tyre wears to maintain snow and ice performance. Also the main grooves are triangular so they wear they open up to maintain aquaplaning resistance. These particular all seasons are also an extremely good wet weather tyre..better than most summer tyres and absolutely better than full winter tyres as the last 20% of snow and ice optimisation isn't compatible with wet weather performance. Given we live in a wet country...it's rare to find myself in a situation where the tyre isn't in it's comfort zone apart from the 2 weeks of summer it's 25 degrees+
However cheap all-seasons and winter tyres don't evolve and some don't even have sipes cut beyond the first few mm and disappear with wear but as ever pay your money...take your choice.
I still have tyre socks in the boot as I remember them seeming vaguely miraculous when I had summers on but the point seems to be if I'm stuck they are unlikely to make things any better on current tyre set up.
Now far be it from me to point out that in most road conditions 4x4 is excess weight and the tyres are what makes the difference. Although I'm sure you could out rock crawl me..
my point is if you are used to the climate there is no problem generally.![]()
