Greasytrucker
Established member
Basically with my Sedici once it’s been started it’s fine, it’s just getting it started when cold! So far I’ve changed all 4 glow plugs and the glow plug relay with no noticeable difference. It’s as if the glow plugs don’t stay on for long enough hence if temp sensor unplugged it leaves the light on for 8 seconds or so and pretty much fires straight up. When you do some trawling there’s a lot of Alfa 1.9 owners that have overcome the same problem by replacing the starter motor. That’s currently where I’m at, just trying to find the time at the moment to fit a used starter I’ve bought to see if it helps. Not really heard another 1.9 start before so nothing to compare mine to as regards it being lazy trying to startI'll try that next, it would make sense for it to be that, its now running but usually starts first time without being rough in summer straight away accelerator works. Is the temperature sensor a replaceable part?
