Ttalor66123
Hi all
Hope someone can help me find a vacuum pump for my 2001 ducato 2.8 jtd
Many thanks
Many thanks
The 2.8 JTD was also fitted to the Iveco Daily. Some Fiat 2,8 JTD components carry Iveco numbers. A difference between the engines was that the sub assembly held the oil filter in a vertical position, rather than in the near horizontal orientation on the Ducato. If you are having difficulty sourcing the vacuum pump, it may help to widen your search to include the Iveco Daily 2.8 JTD vacuum pump, which is probably identical. To help you decide I am attaching a pdf copy of a page from the Iveco Workshop Manual. See Figure 167.Hi all
Many thanks
Hi CommunicatorThe 2.8 JTD was also fitted to the Iveco Daily. Some Fiat 2,8 JTD components carry Iveco numbers. A difference between the engines was that the sub assembly held the oil filter in a vertical position, rather than in the near horizontal orientation on the Ducato. If you are having difficulty sourcing the vacuum pump, it may help to widen your search to include the Iveco Daily 2.8 JTD vacuum pump, which is probably identical. To help you decide I am attaching a pdf copy of a page from the Iveco Workshop Manual. See Figure 167.
Thank you for the feedback, but it downloads back onto my computer OK.Hi Communicator
It looks like the attachment is not opening, when you click on it
