Technical Upgrading Standard Speedo to Digital
Ok.
So what do you expect to change?
So that the ECO button works like the SPORT button. In sport mode, there should be a boost pressure sensor on the right side of the instrument panel. Or do I need to change byte 65=60?
Yes, MES did not make a PROXY and left the standard value of the ECO button. AlfaOBD was also unable to change ECO to SPORT. Maybe in cars of 2018 a different byte needs to be edited? MEC and AlfaOBD only know older BODY?
I doubt the sport
You won't get boost pressure if there isnt a boost pressure sensor connected.
I dont think the twinair has one has it?
No need to change any bytes. I changed it here. (Sorry for the horrible screenshot)
It´s been 2 years, but I don´t think I did a proxy align.
I placed screenshots of normal and Sport mode here:
That's what I did. After changes in MEC, the PROXY alignment procedure does not work, error
PROXI ALIGNMENT PROCEDURE
Writing CAN configuration data ...
Writing to module Body Computer Node (BCM/NBC) FAILED! - Request out of range error
[102A] errors: Byte 83: 08->00
Writing to module Dashboard Node (IPC/NQS) SUCCESS!
Writing to module Airbag Node (NAB/ORC) SUCCESS!
Writing to module Entertainment Telematic Node (ETM) SUCCESS!
FAILED TO EXECUTE
Thanks for the link, I wondered what the difference was. At least my eco gauge works, thats something I suppose.
At the time I didn’t know that the Eco gauge is actually fed by the radio, which I replaced with an aftermarket unit. So that explains why it stopped working 😁
Well all you need to do is find a digital speedo with lower mileage than the car …. And one that is up to 2015!! do not even entertain a 2016 as it is not compatible!
MES will allow you to set the correct mileage and a proxi will write the data to the new digital TFT unit
Just one plug to remove on the rear! I’ve included a pic of mine! Much neater!!
Swapped mine 2/3 years ago no issues at all
I don't suppose you would mind telling me what you have set for byte 65 (I think that's it) for your Proxy Alignment? I want my TFT speedo to look like yours, with the thinner font.
My byte 65 is "00" which is either "Pop" or "Pop/Lounge" according to posts above :)
Thanks in advance!
You have 4 options for byte 65.
"00" - Large Speed Digits and mimics old style fuel gauge and rev counter.
"20" - Small speed Digits and simpler style fuel gauge & rev counter.
"40" - Sport
"60" - Abarth
'00' looks like this...
'20' looks like this...
I can't get 40, or 60 the system seems to know I haven't got a sport or Abarth.
It would be really interesting if people were to check the numbers in between to see if they modified various other text /digit sizes/colours.
"40" - Sport
"60" - Abarth
Thanks.
My car on “00” has an “eco index” of 0-50-100 on the right. I don’t actually know what it means but I do know it moves around, but not in real time it seems. I assumed it was another way to show MPG.
Taken from my car earlier:
Thanks.
Yeah, it's not very good, but is an indication of how heavy footed you are on the throttle, there is an irritating delayed action, which looks like that part of the program only updates 5 seconds or so, ideally you're aiming for the 'shadow' to change to a little green bar right at the top after driving for a while with the absolute lightest of throttle input.
The Byte 65 -'20' setting goes from 1 to 5 and when you get to 'good' 5 it changes to the little green bar (not sure what the '00' setting does for this).
Yes, I suppose it could be, if you have Byte 65 set to '00'
