Didn't think you could change toe angles on the rear due to it being a torsion beam?
Don't think you can either.Didn't think you could change toe angles on the rear due to it being a torsion beam?
Blimey! My 500 is on original tyres @ 14k miles and they've worn pretty evenly across the tyre and the tread depth is about 5-6.5 mm so I'm expecting around 30k miles from the full set if I rotate them which I have been doing. Strangely there haven't really been many complaints from 500 owners about uneven tyre wear.
Sadly for the rear tyres there is no adjustment for toe or camber so nothing can be done about the rears. Wonder if pressures are too high or too low?
All perfectly true, but other car manufacturers seem to manage to get their car's tyres to last a bit longer.......Front wheel drive cars tend to toe out at the front, this and the negative camber that's present will almost certainly increase tyre wear
<snip>
What can you do to help?
Check pressures weekly
Wheel alignment checked when buying a new set of tyres
Slow down for them speed humps
Have the car moving a little before you swing on the steering wheel (you older drivers will remember the days before PAS)
Ask for the rear axle bushes and front wishbone bushes to be check (they should pry them with a bar) every service.
