jayartibee
- Joined
- Oct 18, 2019
- Messages
- 26
- Points
- 61
'07 Panda Active is wearing rear tyres out on outside shoulders. Anyone know how to adjust rear tracking?
I was wondering when someone would get round to thisHow is your tirepressure?
gr J
Seriously, Its a Panda not a PorscheMy tracking and camber checked out fine but the car always pulled Left and scrubbed the front tyres.
The rear axle uses bolted on wheel spindles using 4 bolts (studs actually) each side. Some slotted shims made from coke can aluminium allowed me to tweak the rear toe (back edge on one side, front edge on other side). The pull has stopped and tyre wear improved.
It's a small change and easily reversible.
as expected. there is very little geometry to keep the car in a straight line.I pulled the power steering fuse. It made zero difference to the steering pull at motorway speeds. I also had the tracking carefully centered (steering wheel sits straight when driving straight). The pull to left problem went away after carefully shimming the back axle.
HOWEVER I have not checked if MES can correct any electronic steering alignment issues. Thank you for the heads up.
