Tuning turbo time!
Tuning turbo time!
thanks munkul.
made the tool to hold the tappets in. worked brilliant.
all the tappets are mint. not a mark on them :)
been taking two apart and found some interesting differences. mainly the valve springs.
I have a 1368cc head under my bed. I think the valve are the same size on that as well. Only difference on this particular 1368 is the intake channels and the inlet bolt position due to being a starjet. My other 1368cc non-starjet was the same as my 1242 as far as I recall.
Kristian
//edit -- comparing todgers 1242 16v block with the 1368 block shows them to be exactly the same other than the bore.
its the same basic bottom end then yes.
I always fancied fitting the 800cc fire crank into a 1242 block (machined down). it would make a 1000cc engine with the same bore and stroke as a R1 bike engine.
this fitted with a 16valve head and the right cams could make for some fun.
but yeah the way id do it if it was me and possible is just buy a set of 1.4 pistons and fit them on the 1.2 rods and get the block bored out to match. end up with a capacity of 1285cc(72mm bore x 78.9 stroke)
or even a 1.1 crank which will require either custom rods or pistons 1173cc with a 72mm bore and stroke... be great screamer/high hp engine but would need a very well ported 8valve head or a 16valve head with some work to stiffen up the lifters.
imho the 1.4 is a bit to much of a long stroke. good for a heavy car as it makes tons more torque but centos (Again imho) require less torque and more hp to get the job done (hence why im looking into the 16v turbo as it will give more hp without so much torque)
If you in need of a standard 16v exhaust manifold ive got one in my garage that you can have if you pick it up
would love to see how well the 1.2 16v copes with a turbo
Ash
is that for the old mk1 head? without the manicat? think ill end up making a proper turbo manifold once i get a new drive belt for my drill press.
Main reason is I have everything (the tools) to make a proper manifold, but dont have the gear to weld cast iron.
the proper manifold will take longer but im in no rush.
heres some photos of the progress.
First head stripped of valves and seals
First bucket of valves
2 heads totally dismantled. one more to go :(
intake manifold modified to hold the much larger injectors(in flow and dimensions). had clearance issues with the throttle body but noticed if I flipped it there was no problems, just needed to add new mounts and will have to extend the fuel pipes on the car to reach the other side of the engine.
I have a returnless fuel rail but id still need to add brackets because the larger injectors.
Id also have to buy a fuel pressure regulator and mess about with fuel lines.
cinqs are already set up with a return unlike cheapo seis :p lol
also running without a return is not brilliant. you get more fuel pressure fluctuations and any air in the fuel (which you will get) has no way to escape other then through the injectors.
its all fine for a n/a production car but defiantly not good for a turbo.
I was mainly hinting at the bravo rail as it's thinner and might not be as intrusive on the throttlebody but I have a feeling it's not the size that is a problem :D.
I have some added toy that came free of Mr. Kritip last night, quite tempting to play with.
X
no offence but that sounds like tosh. Theres no way a returned system will have less air in than a returnless system.
Yes possibly an uprated FPR will be better than standard, but tbh I have watched my fuel pressure gauge like a hawk on the dyno and never saw any fluctuations apart from when at idle.
X
ahhh I think either way its tight. the new injectors are twice as long as the crappy fiat ones.
even with the rail flipped the regulator touches the throttle body just slightly. and needed turning as the pressure hose was in the way
