Transfering a PC
Transfering a PC
thats pretty cool
id like to make a desk that has like a tray on the legs then the top is made of perspex and you can run all your wires etc in the cavity and then you can just drill a hole where you want the wire to come up.
Consider yourself lucky, I'm restricted to a 18" coffee table!
Unless your going to use the CD much then it still works on its side (motherboard side of case).
You can get desks off of Freegle/Freecycle for nothing or get a smaller one and a sheet of Melamine/MDF from B&Q for on top.
And if the current case is in good condition and it works then work around it rather than waste a good case by buying another.
I know - I'm a spoilsport... :)
I'm now thinking thats the best option.
My Desktop is on the floor, this is my setup:
I work from home, so this is in my dining room/study :)
at home i have duel, 24" screens, ones a tv and the others a monitor. they are not together. instead i have found it usefull if i need to copy data from a photo and getting confused, making it look like a seperate thing helps. (i could never play over 2 moniters)
So I have decided to keep the Alienware ‘as is’ and put it on the floor until I can find a suitable table.
My brother has wiped the drive and reinstalled Vista (via a recovery CD). It’s a 350GB Hard Drive.
My PC is XP, a 500GB drive and has been partitioned. (OS/Games/Work/Spare).
Is it possible to transfer his Vista onto the 500GB drive? Should I leave his drive as the main OS drive (i.e. put nothing else on it) and install my 500GB drive as a second drive, into the Alienware PC. Which OS would boot? Would I still be able to access all my games and work?
If it were me, and I'm assuming that your broadband router has a few ports, I'd plug both machines into the network and copy everything you want kept from the old machine across to the new one into a temporary folder, once you saved everything you need from your 500GB drive whip it out of the old machine, pop it in the new one and format it, then copy back from your temp folder. That way there's no dual OS confusion and it gets rid of any accumulated trash (and there will be some) that'd been floating around on your 500GB drive.
That sounds like good thinking.
How would i get both PC's to 'see' each other. One is XP, the other is Vista. ive asked before and was told its not possible.
personally i would lose vista.
if you install the second drive you can boot to either os you just have to change the boot priority in the bios.
just saw the other reply's and Eklipze3k has the best idea imo
I also agree with jip0, ditch Vista asap, XP might not like some of the newer hardware in the Alienware though. You should be able to pick up a Vista > Win7 upgrade fairly cheap I'd have thought.
Having never paid for Windows I've no idea ...
