Technical Torque settings clutch replacement
This weekend we will be bravely attempting a clutch replacement on my daughters punto (year 2000)
I have the instructions (thanks to this forum) but I don't have the torque settings that might be needed
Can anyone advise
Thank you in advance
Mick(y)
i would rather feel the tight rather than torque the tight
remember to make sure the diaphragm is flush to the flywheel before doing final tightening
tbh the clutch job doesnt need a torque wrench
use if uve got it
not to worry if you don't
just ensure the clutch is perfectly aligned before doing the box method to tighten up
since they come in 3 sections ( 6 in total - 2 bolts.are quiet close together)
so consider it more triangle method
ziggy
